‎2005-06-13
06:07 AM
‎2023-05-11
01:55 PM
Noemi Balogh
another wrote:now lightworks is obviously implemented to varying degrees of complexity in different applications, so i guess my question is: just what is the lightworks engine
... For instance, indoor lights will not shine through a glazed window and light up the ground outside. Similarly, light will not shine through a translucent lamp shade, even though you see through it. ...
‎2007-02-09 07:02 AM
‎2007-02-09 07:05 AM
‎2007-02-11 11:11 PM
andyro wrote:yep - more like your 'milky white plastic'. does it have a window light behind it to accentuate the translucency?
Do you mean like this?
‎2007-02-12 01:24 AM
~/archiben wrote:andyro wrote:yep - more like your 'milky white plastic'. does it have a window light behind it to accentuate the translucency?
i was aiming for a two-skin polycarbonate cladding system. i wanted to see if i could render the translucency before i tried to apply the 'ribbed' effect.
the thing that i dislike about your 'milky white plastic' is the dull grey area in the bottom left - out of direct light. i found that when i boosted the specular or reflectance to compensate, i lost the transmission . . . and with it any translucency i had achieved. by then i had more deadlines to meet so gave up . . .![]()
ben
‎2007-02-12 01:25 AM
‎2007-04-30 07:31 PM
‎2007-05-01 07:02 AM
‎2007-05-02 01:28 AM
Long wrote:long tran,
do you mind posting the setup of your translucent milky glass?
‎2007-05-02 05:32 AM
‎2007-05-02 06:16 AM
