2023-10-12 01:32 AM
hi so I've created new fills, surfaces, building materials & composites for walls (I made it to fulfill the standard in Indonesia) but when I tried to create the new walls that I've created, the line symbol didn't show up. what should I do to fix it?
2023-10-12 03:10 AM
Please provide screenshots of your fill settings. It would also help if you include some information about your system setup. Refer to the links in my signature about creating a post and adding a signature.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2023-10-12 08:35 PM
this could be a huge range of reasons your elements are not shown as their settings say they should.
-graphic overrides
-renovation filter
-on screen view options > show vectorial vills
-in section/elevation, the cut and/or uncut lines, fills, pens can be overwritten in the viewpoint/marker settings
-trace reference could be on and set to show fills transparent
-pen set could be using white pens for fills or skin separator lines for the pen set applied to the view
-walls could be set to "outlines only" or otherwise cut settings do not qualify it as a cut element for given floor plan cut plane settings
-fills have not been tracked through to correct bMats and Surfaces as their relevant sub attributes
-default pens for surfaces or bMats are a white pen
As @Lingwisyer said, screen shots of the element settings and what they look like would be a good place to start sleuthing this out
2023-10-18 12:42 PM
Thanks, I will check and if I still face any issue, I will share the screenshot.
