scrptdfalls
my new composites didn't show the lines that i've created from the cover fills
hi so I've created new fills, surfaces, building materials & composites for walls (I made it to fulfill the standard in Indonesia) but when I tried to create the new walls that I've created, the line symbol didn't show up. what should I do to fix it?
3 Replies 3
Lingwisyer
Guru
Please provide screenshots of your fill settings. It would also help if you include some information about your system setup. Refer to the links in my signature about creating a post and adding a signature.
Ling.
Patrick M
Ace
this could be a huge range of reasons your elements are not shown as their settings say they should.
-graphic overrides
-renovation filter
-on screen view options > show vectorial vills
-in section/elevation, the cut and/or uncut lines, fills, pens can be overwritten in the viewpoint/marker settings
-trace reference could be on and set to show fills transparent
-pen set could be using white pens for fills or skin separator lines for the pen set applied to the view
-walls could be set to "outlines only" or otherwise cut settings do not qualify it as a cut element for given floor plan cut plane settings
-fills have not been tracked through to correct bMats and Surfaces as their relevant sub attributes
-default pens for surfaces or bMats are a white pen
As @Lingwisyer said, screen shots of the element settings and what they look like would be a good place to start sleuthing this out
RobbLittle
Thanks, I will check and if I still face any issue, I will share the screenshot.
