Visualization
texture display error
hornett
After reopening the model all displayed textures turned somehow into brick - the thing did not appear when I was saving it the last time - the material itself also did not change just the texture. Does anyone have any idea how to fix it?Zrzut ekranu 2023-04-18 000553.png
julienK
You have a graphical override enabled, it might come from this.
julienK
hornett
Yep that was the problem - thank you v much for the solution
