textures on windows / doors
Is it possible to have the texture map on windows and doors applied the "correct way" ie the transoms and mullions should have the texture running different directions (see attached pic showing texture the same way)
Hope this makes sense!
32 Replies 32
Djordje
Not at this point of time ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
It actually may be possible. Some library parts are scripted to do this correctly (at least mine are). You may be able to find one that works. If you are a fairly proficient GDL user, you could make/modify your own.
Djordje
Addition: ... with out of the box parts.
Thanks for the correction, Matthew!
Djordje
HP Omen
You can do it!!! With out GDL Knowledge.
1. Option > Attribute Settings > Materials..
2. Choose the material.
3. Type numeric for set degree. 90 is rotate the material in vertical direction.
a pice of cake
TomWaltz
except that does it EVERYWHERE, not on various parts of a single window or door frame.....
Tom Waltz
oH"" If you want change on various parts of a single window or door frame..... You can duplicate the material and create new several material for a single window or door frame.
New material
Frame material
