2006-01-05 11:35 AM - last edited on 2023-05-11 01:00 PM by Noemi Balogh
2006-01-05 03:48 PM
Lennox wrote:Not at this point of time ...
Is it possible to have the texture map on windows and doors applied the "correct way" ie the transoms and mullions should have the texture running different directions (see attached pic showing texture the same way)
Hope this makes sense!
2006-01-05 04:04 PM
Djordje wrote:It actually may be possible. Some library parts are scripted to do this correctly (at least mine are). You may be able to find one that works. If you are a fairly proficient GDL user, you could make/modify your own.Lennox wrote:Not at this point of time ...
2006-01-05 04:13 PM
2006-01-06 04:24 AM
2006-01-06 04:25 AM
2006-01-06 04:30 AM
2006-01-06 04:58 AM
2006-01-06 05:05 AM
2006-01-06 05:06 AM
