2020-04-23 01:12 PM - last edited on 2023-05-11 03:52 PM by Noemi Balogh
2020-04-23 01:55 PM
2020-04-23 03:01 PM
Jp1138 wrote:Yes textures are shown in the library
It seems your textures are missing? Do they show when you open the material in the material library?
2020-04-23 03:13 PM
2020-04-25 12:41 PM
2020-04-26 07:44 AM
LaszloNagy wrote:An easier method to find the Surface, in the 3D window, select the Wall(s), and open the Surface Painter palette. It will show you the Surfaces assigned to the selection (on the right hand side). Double click to open the Surface attribute settings.
Or, select the Wall showing the purple-black pattern.
Go to the Wall Settings Dialog. The Surface either comes from the Building Material, or there is a Surface Override applied to Wall sides.
So find what Surface is applied and then in the Surfaces Dialog check the Texture assigned to the Surface. It will be missing. So you either have to make sure the Texture applied can be found in the loaded Libraries, or you have to apply another Texture that is available in the loaded libraries.
2020-04-26 02:55 PM
