2005-04-2903:44 AM - last edited on 2023-05-1112:37 PM by Noemi Balogh
use of the lightworks 'floorboard' shader = reflectance bug?
2005-04-2903:44 AM
dwight / anybody . . .
i've been trying with very little sucess to use the 'floorboard' lightworks shader. whatever i seem to do it renders with a very high reflectance resulting in an almost all white/glare render.
i've even started with the basic timber materials (which renders ok) and then simply switched the shader to floorboard: still loads of reflectance/glare . . .
has anybody had any luck using 'floorboard'?
cheers
~/archiben
b e n _ f r o s t b f [a t ] p l a n b a r c h i t e c t u r e [d o t] n z archicad | sketchup | morpholio | phpp
