white walls grey
i have been trying to render an interior for days that has white walls. It seems as though it doesn't matter how many lights I add or remove, how many times I tweak the element attributes, etc. etc., I still come up with gray walls. What am I doing wrong?
14 Replies 14
here are the settings for the light effects. For texture, in the internal engine settings I have checked surface, ambient, and bump mapping.
lightworks engine settings
tigr wrote:
Below are raw samples, no postwork.
no postwork needed! is that rendered with lightworks?
stefan
tigr wrote:
A tip of a day:
There is underestimated material setting called "Pipeline". When use carefully can be very helpful in getting white walls without crancking light up to the supernova bright value. Of course roughness is his friend.
Very nice and fine to see good quality out of ArchiCAD directly.
The lighting is rather soft and pleasing. Did you use Windowlights?
Archicad-user since 1998
my Archicad Book
Could you please post the material settings?
Reflectance: Plastic
1.0
1.0
0.2
0.3
Colour: Pure white
Displacement: Rough
0.1
0.1
3
3
Pipeline:
Colour - 36,36,36
Attenuation - 0.0
As always
To be honest I cannot tell for sure, it is an old project which has been modified since, but either it was combination of WindowsLights pointing up and down or LightCones pointing up and down. For interiors I found this solution to be most convincing and fast same time.
