Noemi Balogh
Archicad 26 for Apple Silicon – Tech Preview launch
Have you heard the news? Tech Preview for Archicad 26 Apple Silicon version is out! Check the news on Graphisoft Insights.
What is your experience with this version? Let us know!
Noémi Balogh
Staff Community Expert, Admin
94 Replies 94
furtonb
Yes, Teamwork is a problem...
When can we expect a compatible release with the current Intel-based AC26 4019 build?
odv.hu | actively using: AC27-29 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
When the release version of the Apple ARM build is published by the end of the year.  The current ARM builds are previews only for getting a sense of what kind of speed difference (other than TW of course) to anticipate… and to report any issues to Graphisoft’s so that the release build will be as solid as possible.
furtonb
I would like to try it on ongoing projects and provide feedback. a minor problem is, that our projects are almost exclusively TW projects. there is no solution then.
Jose Gradoli
GS would have a lot of feedback if AC26ARM matches TW versions.
www.formaarquitectura.com
ARCHICAD 25 SPA
Studio_Pi
thank you for the opportunity to experience ARM before the official version is released.
my first impression is that everything is working in about X7 times faster than the intel based version. The files are opening faster - navigation between views is faster - cineware is working faster, but only in about 2% more (i'll take any % there).
All and all looks great - looking forward for the official version 🙂
Thank you again!
Joash Halevi, Licensed Architect | Studio Pi
Mac studio MAX, 64 ram, 32 gpu.
Archicad 26.0 | Mac Os Ventura 13.0
Mario Sacco
I found some problem in the preview of the interface in creating objects.
The command "UI_LISTFIELD" doesn't work fine; the window of the command extends outside of the setting window..
It works fine instead in the definite version when the object is published.
I think the problem is also in preview versions.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
Mario Sacco
I made some considerations on the last update on Grasshopper connection.
There was some issues; it seams the previews version worked better with objects, on managing connection.
https://community.Graphisoft.com/t5/Design-forum/Grasshopper-Connection-New-version-4023-and-palette...
rikhav
Since the Public version of Archicad 26 ARM is out now, I just wanted to know, whether the same is macOS ventura ready or not.
Eduardo Rolon
It matches the current MacIntel version so it has the same bugs like “erasing” the first digit in the tracker and unable to scroll lists. Because of this and based on GS reasoning it means that it is not ready for Ventura. Still I am using it without other issues.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Mario Sacco
The new link to download the Grasshopper plugin connection for ARM Silicon AC26 doesn't work to me.
https://Graphisoft.com/downloads/addons/interoperability/rhino
Because the release version of AC 26 for Apple Silicon / ARM processors (M1, M2, etc) is out, I am closing this topic to new comments.  Please raise any issues on the release version in whatever forum here most closely matches the issue discovered.  Thanks.
https://community.graphisoft.com/t5/Graphisoft-Insights/Archicad-26-Apple-silicon-version-available/...
