I guess it will be useful to directly link a dimension to the lenght of a thermal bridge.
For example right click on the dimension and have an option of linking to a thermal bridge and then a menu appears with the thermal bridges available.
Also in case of an alteration at the dimension on the plans, the link should also update the length at the relevant tab of the thermal bridge.
With that way the data for the thermal bridges are kept updated even if something is change at the design level.
