Read more
Wishes
Edit selection set - renovation status
stoneunturned
Interior Elevations and pasted images prevent a blanket selection of elements from having their reno status changed.
Eg. below snip shows the selected elements whose reno status id like to change + the offending culprits that remove the Renovation Status option from Edit Selection Set. The user has to deselect these before continuing which slows down the whole process, especially when the offending items aren't obvious - in other words it can be an arduous hunt for what's causing it and undermines the speed of the Find&Select > Edit Selection Set process.
I'd suggest if some elements do not have a renovation status (though arguably everything should) then the option should still appear with no changes applied to the non-statused elements.
Win11 AC26 7004 NZE FULL
Dell G15 Laptop: i7-12700h, RTX 3060, 64GB DDR5
Thunderbolt 4 to 2 screens, HDMI to a 3rd screen. Laptop lid remains closed.
3dconnexion mouse and keyboard
0 REPLIES 0
