2018-01-22 10:26 PM
2018-01-23 02:43 AM
2018-01-23 02:17 PM
2018-10-11 04:29 PM
Barry wrote:Ok, that works but no for the background colour of that fill... So is it reaching half way only, isn't it?
Slabs don't have fills in plan unless you activate the cover fill option.
You can set the cover fill to use the 'Fill From Surface' material so if your top slab building material (or top surface override if you are using that) has the correct fill then you will see it automatically in plan as you change the material of the slab.
2018-10-12 03:21 AM
Leire wrote:You can control the hatch pen colour and the background pen colour.
