Wishes
French Leaf
JGoode
I've got a pretty simple request for the French Leaf to just change the direction of all the sides to go the same direction. It doesn't look very nice when using a surface with a grain!
ArchiCAD 23
Windows 10
2 REPLIES 2
Are you referring to the French door leafs?
The grain should follow the length of the timber member, which it does - except for the grids (glazing bars).
The timber grain should never run in the same direction for both the sides and top/bottom - doors just aren't built that way.
This is an image from the AUS library, it could well be different in other versions (but it shouldn't be).
Lingwisyer
Guru
Rather, it would be nice of you could set it to mitre to corners rather than butting.
Ling.
