Are you referring to the French door leafs?
The grain should follow the length of the timber member, which it does - except for the grids (glazing bars).
The timber grain should never run in the same direction for both the sides and top/bottom - doors just aren't built that way.
This is an image from the AUS library, it could well be different in other versions (but it shouldn't be).
