2021-07-13 10:51 AM
I would reinforce it with a Graphic Override that highlights the changed elements the same way as missing textures or inverted elements are highlighted. At least then you might be able to find the changes rather than the fairly anonymous reporting we get in the Check & Repair process.
2021-07-13 11:26 AM
2021-07-13 12:42 PM
2021-07-29 03:34 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
