2023-04-05 02:46 PM
We work in the motor industry and part of our work involves using vehicle tracking software in 2D & 3D. Currently we have to have a full version of AutoCAD to run AutoTURN.
https://autoturnonline.com/integrated/
Why does Graphisoft not have a plug in for something like this? Using library tracking curves is not enough.
Can Graphisoft advise why they don’t have a link to a dedicated tool, this must be a requirement of other designers. The inclusion of this would mean that we could remove the need for AutoCAD completely.
We look forward to your help on this.
a month ago
Try it in Vectorworks.
Friday - last edited Friday
The CI tools tracking curve objects are still available to subscribers, and work ok in some situations but have a number of deficits - the main one one is that they are quite poor at handling multi-point manoeuvres. Also the 2D plan view symbology is inconsistent between vehicle types and has bugs as to which pens/line types actually change when a parameter is changed.
Unfortunately CI no longer seem to be actively involved in maintaining their tools,
Friday
There are 8 different turning curve objects in the default Graphisoft library.
I have never used them so can't say if they are goos or bad.
Just that they are there.
Even worse than the CI tools ones unfortunately - essentially dumb diagrams
