2005-10-31 02:04 PM
2005-10-31 03:51 PM
2005-10-31 08:55 PM
Paul wrote:Paul, you know you have different display options for cut fills, drafting fills and cover fills?
Also would provide a method of creating an outline only plan as a backdrop for other graphical elements to be placed over - eg services through & along walls, beams etc - such that walls that otherwise need to display as solid filled do not mask other elements in a view set up pmarily to show those other elements , and such that switching off all fills in display options is not required to access outline only view of walls - i.e. where fills are still required for other elements.
2005-10-31 09:26 PM
Paul wrote:paul
Hope this makes sense - Could be quite a powerful feature!
