2005-01-11 11:00 PM
2005-01-12 06:24 AM
rwallis wrote:the solution as i see it is a hierarchial layer list - i think that it's essential to keep x-ref layers and project layers within the same list because layer combinations often require one or two layers from an x-ref as well, no?
I prefer to see x-ref layers in a group on their own especially as often AutoCAD users have different layer names due to their workflow processes.
Mixing these through the Layer list as currently occurs is a nightmare IMHO.
A quick and simple "fix" would be if GS could add to the DWG plugin an option to add a (definable) prefix to each of the layer names upon import. Who knows - we could get this increased functinality before the next release as it is a simple update to the plug-in!when attaching or overlaying an x-ref, archiCAD prefixes the layer name with the name of the file and a pipeline (eg. a_dwg_file | a_layer_name). the trouble with this is the number of characters allowed in this newly created name often means the truncating of important information. whether this lies on the DWG side or the archiCAD side i'm not sure, but fixing this would seem to provide a solution as well.
2005-01-12 07:30 AM
2005-01-12 08:45 AM
rwallis wrote:ah! so a semi-automatic workaround for you at the moment would be to rename your dwg files to "Z_shortfilename" and use the x-ref functionality. archiCAD would then add the 'prefix' for you as a part of the x-ref process
I add a Z- OR X- to layer names before linking the file (so it is a hotlinked PLN not a strictly an x-ref) so that the layers group together near the bottom of the layer list...
BTW how is the view from your hammock, or have you avoided the tsunami?all is well thank you! i was on the other side of thailand - didn't even get a tremmer. it's really surreal being so close (a couple of hundred kms maybe) to such a tragedy without seeing, hearing or feeling any of the fallout. funny old world.
