Wishes
Zone 3D Export
owen
ArchiCAD should allow the export of Zones in 3D formats.
We render most of our presentation stills and animations in Cinema4D. We would like to be able to maintain a consistent workflow in early design stages using Zones for massing studies - impossible at the moment because we cannot export the Zones.
I know Zones are not strictly the same as other 3D elements (as Mathew points out here) but I can see them in the 3D window, so ArchiCAD has defined a 3D form for them - so I don't see why it would be difficult to convert this into various 3D formats for export.
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
5 REPLIES 5
owen
OK fixed ..
seems i had to actually add the Poll options
has this changed recently? I thought if you didn't specify your own it used the defaults (Essential, Important, Moderate, etc)
cheers,
Owen Sharp
__archiben
only when you post a topic in the wishes forum
whilst not essential - sorry owen - i can definitely see the benefits. i think primarily the zone needs to be more easily manipulated (ala sketchup pushpull stylie), before it can really be called a genuine massing study tool . . .
this, on the other hand, is most definitely an essential one . . .
~/archiben
b e n f r o s t
owen wrote:
OK fixed ..
Yes, but in the "Wishes" section.
Edit: you're quick, ~/ben, and I like your thinking on the push/pull idea.
owen
~/archiben
double
can any mods move this Topic into the appropriate forum please?
well i had to vote Essential for my own poll didn't i? Completely understand its not going to be high on peoples lists though.
and i really like the idea of more SketchUp like modeling abilities in ArchiCAD for quick design work. The SketchUp import I have experienced in ArchiCAD is completely useless
Yep. But I think if they fix that, then they will have fixed this also
cheers,
Owen Sharp
__archiben
i think you're right. fair call.
~/ben
b e n f r o s t
