Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
export ArchiCAD pen sets into AutoCAD CTB files
I wish there was a way to export ArchiCAD pen sets into AutoCAD CTB files and import CTB files into ArchiCAD pen set
Original post: http://archicad-talk.graphisoft.com/viewtopic.php?p=99936#99936
10 REPLIES 10
I just want to reiterate how much of a time saver this feature would be, especially the ability to import consultant .ctb files.
I honestly hope the ArchiCAD developers take note of the overwhelming response that this is an essential feature (albeit from a small sampling of people)
Please, if you have not yet voiced you opinion - vote!
And vice-versa!
JaredBanks
Mentor
I know this is an old wish, but at least half of it has been fulfilled sometime in the past few years:
http://help.graphisoft.com/ac16_help_INT/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=01_Configurati...
We can save out to .ctb now.
Jared Banks, AIA
Shoegnome Architects
Still on AC14(USA) - The Save As...CTB is not an option. Or is it only an International version option?
Really looking for a way to send the Pen sets.
JaredBanks
Mentor
must have been a 15 addition... (yup. just checking the online help files, this option isn't there in 14, but appears in 15).
Jared Banks, AIA
Hi
I really need to IMPORT a dwg file and Autocad CTB file into Archicad so I can work with a dwg drawing provided by my autocad technician and print the drawing with the same lineweights he has created. How can I do that? He is on Autocad 2010 and I'm on Archicad 16. Isn't there an Import CTB setting?
thanks so much
Christopher
JaredBanks
Mentor
I don't believe there is an import. You could manually match the line weights to the pen number. Or save back to autocad and print there? Can't remember if there's a better option.
This will help too:
http://www.archicadwiki.com/DWG/Import/MatchPenColors
Jared Banks, AIA
Hi JaredBanks,
Thanks for link
Although I have a doubt regarding the step "open DWG" , how can I attach Xref ?
Thanks
Kind Regards
Caroline Ds.
JaredBanks
Mentor
http://helpcenter.graphisoft.com/tips/xrefs/
Jared Banks, AIA
