More flexible design for Windows and Doors
Leire Bilbao
More options for design of windows. Infinite combinations of portions and openings.
If I want to have 3 sliders, with top hung window over and a bottom fixed transom and a sidelight, I should be able to do it.
No need for a million types of windows, just make the "variable" window FULLY variable so I can add as many parts I want with whatever openings I want.
17 Comments
Danmardan
Great point,
1 - we need windows for more specific frame like passivhaus standard windows: https://www.passivhausfenster.com/en/homeowners/products/smartwin
2 - we need conectivity for passivhaus and for wood or straw wall panels settings.
3 - working reveal settings in 3D supporting structure of the wall not only in 2D!
4 - in the shading setting we need more options:  shutter to insolation maybe
5 - frameless settings for fix + opening window
saggyhaggis
I should also add.
When changing a window to a different opening arrangment / type, all the previously defined properties of the opening are lost which is time consuming to rectify.
DOWA
@saggyhaggis
If you select the window or door on floorplan/section/3D... and then pick up it´s properties with the eyedropper tool (ALT), then go into it´s settings and CTRL+ALT (syringe tool) + click on an other window/door type. It will inherit the properties.
saggyhaggis
@DOWA Thanks for this nugget of information!
This is never mentioned in any presentations or discussions that I have seen.
ArchiProject
I suggest taking inspiration from Allplan's windows, where you first define the characteristics of the window, then you insert it into an opening of any shape and it adapts.
Pedro Melo
I'm a regular user of LPM, so much to the point that I don't mind Doors and Windows aren't parametric, I can't remember the last time I used Archicad's Doors and Windows in any stage after conceptual design.
I've been advocating for something like this for years.
Nowadays a believe LPM would solve this problem perfectly but it needs further development, namely:
• Improved Handling of Non-Rectangular Doors and Windows https://community.graphisoft.com/t5/Wishlist/Library-Part-Maker-Improved-Handling-of-Non-Rectangular...
• ability to create parametric objects (width, thickness, height of elements)
• Ability to create any type of archicad objects (curtain wall panels, taps, etc)
Shaun Coomber
Status changed to: On hold
Thank you for the suggestion. This is the direction we eventually would like to go as a longer term aim. However in the short term we plan targeted fixes with the existing doors/windows based on local needs and requirements. For example we have introduced a new sliding flexible door in an Archicad 28 library update.
Status
On hold
with 203 Votes
Wish details
Product
Labels
