Replace Keynote to interact with tranfer settings
thomaslodge
Currently, the keynote replace tool/option (accessed via a right click on the desired keynote) transfers all the settings in the favourite selected in the keynote palette. It currently ignores any of the settings in the element transfer settings. This means you need a favourite for each layer you will have keynotes on and remember to change the favourite before applying the replacement.
2 Comments
James B
Thanks for the wish, can you elaborate on which settings you'd prefer to ignore when using the replace function?
thomaslodge
The settings that should almost always be ignored are: Layers, renovation, pointer angle, text angle/ orientation, - essentially anything that changes the position or if a label might be seen on a layout.
Then optional to ignore would be: text font, text size,  arrow head.
Status
Open
with 0/200 Votes 0%
Wish details
Product
Labels
