Story Height and Buildings...
snow
Hello together,
Of course, I'm not the first one who writes and "wishes" something in these realms.
But I miss different story-levels and height for different buildings in the same project so yearningly.
Earlier the slogan of Archicad was always: 'The program knows stories, floors'.
Today I liked so much to say 'Archicad knows buildings'.
51 Comments
Erik Bjornhage
I will also bump this one - not because I think that we need to copy Revit but rather that we need to find a better, more flexible solution.
We need to be able to set up general information entities/groups/systems which can be different buildings or part of buildings and we need to be able to set up multiple coordinate systems with free reference levels which can be for different buildings or part of buildings.  is a related wish for the later.
Leon_ARCFLO
This needs to be incorporated.
vdentello
I gotta say we need at least something like sub-levels
For example, I could have Second Floor Finish level and second floor relative ceiling level.
That'd be wonderful. Could also handle different floor levels.
Different buildings with separate non-related levels within the same model would also be the dream.
Erik Bjornhage
I think the key here is not to have an infitnite amount of reference levels (like Revit) but ratehr a working solution for mezzanines, half-levels, entry-levels or situations where the building itself has different levels that don't necessarily follow a strict whole-floor-to-whole-floor setup.
vdentello
Good point. Revit extra reference levels add up to the IFC levels exported, when their tick box is marked, which makes very hard to maintain links/ references.
Botonis
Mentor
This problem is solved with the indigo story marker!!!!!
https://www.indigofigs.com/story-marker/
Create new stories in elevations/section, offset, format, etc.
Once you start unsing it you cannot live without it.
Shaun Coomber
Status changed to: On hold
Thank you for the suggestion and comments. While we have been investigating ways to improve existing workflows, the plan is to focus on larger developments around renovation first. For now the status has been changed to "on hold".
Erik Bjornhage
Interesting - because the issue that this wish adresses is particularly important when dealing with existing constructions (buildings)...
hmartell
I would love a hierarchy:
Building / Story / Level.
Buildings can be defined as a groups of Stories, and within those, you can assign stories and levels (as many as you want)
Levels are reference only as they are now, stories create floor plans as they do now. The "relative to_" options could be pull-downs for most flexibility
Event Center: 465'-3" Sea Level
-Basement [story]: -12'-0" (Relative to First Floor or Fixed to another sea level elev)
  - Elevator Pit Level : -3'-0" (Relative to Story)
-First Floor [story]: 0'-0" (Relative to Building Elev or Fixed to another sea level elev)
   - Stage level: +1'-6"
   - Patio level: -0'-1/2"
-2nd Floor [ story]: 15'-0" (Relative to First Floor or Fixed to another sea level elev)
Catering Building: 465'-0" Sea Level
   - Level 1:
These could have the UI of Design Options & Keynotes (Nested items in folders etc)
Status
On hold
with 110 Votes
Wish details
