I completely agree. The easiest solution would be for windows, doors, skylights, etc. to function as an opening tool, as this would enable some additional functionalities.
If we had this functionality, we could:
Sometimes you have a wall made with two separate walls next to each other
In renovations, add a new layer (wall) and connect the window to multiple elements.
Connect the skylight to multiple roofs - sometimes the roof is composed of several parts, especially if, for example, one part of the roof is insulated and the other is not.
Additional functionality: connect windows and doors to a curtain wall, which even the opening tool cannot currently do. Sometimes the final layer of the facade is made with a curtain wall (slats, suspended facade, ...) and currently openings need to be made manually.
half-height something applied on a facade, happens a lot. If the window/door had an option like "openings" to interact with something else, that'd be awesome. (Event to a slab/ ceiling, regarding the tracks that touch the floor)
I would like to add that what ever is used in the Opening Tool be added to doors, windows and alike, instead of current way that is used for the same elements. Cause for the cases you have just exposed here it would work like a charm
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
