Wishlist | Ability to show Solid operations in plan view
I feel like I'm missing something here, but when you perform a solid operation (for example: cut a flat area out of a sloping site mesh) you can see that affect in all views except plan views.
My wish would be to have the ability to show all object accurately in plan, which would include there current shape, not their shape prior to being operated on
"plan view is an orthographic projection of a 3-dimensional object from the position of a horizontal plane through the object. In other words, a plan is a section viewed from the top. In such views, the portion of the object above the plane is omitted to reveal what lies beyond. In the case of a floor plan, the roof and upper part of the walls may be left out. Basically, a plan view is just another name for the top view of a 3D object".
3D ViewElevationPlanSection
58 Comments
@Josh Verran -Legacy- Agree with your wish, but please search the forums before posting a new wish.  This has been wished for since at least 2008, from a quick search of "solid element operation plan view":
https://community.graphisoft.com/t5/Wishes-forum/Have-the-2d-plan-view-reflect-SEOs-made-to-3d-objec...
https://community.graphisoft.com/t5/Design-forum/Solid-element-operations-Plan-view/m-p/215310
https://community.graphisoft.com/t5/Design-forum/Solid-elements-operation-SEO-don-t-show-on-plan-vie...
https://community.graphisoft.com/t5/Design-forum/Solid-element-operation-floor-plan-display/m-p/2862...
Over the years, Graphisoft has acknowledged how important this is to most of us and assures us that it is high on their list, but is more complicated than we think it would be (in order to maintain good 2D performance).
Still, folks should 'like' yours and other similar wishes to show support for this. 🙂
Good point, thanks Karl.
I will go "liking" on those posts.
Johan Stinckens
Karl,
I'm sorry, but I kindly disagree!
If any of these posts had resulted  in an actual solution that would be absolutely right.
There would be no need for a new topic or replying to a rather new one.
So GS is promising this since 2008, and there's new topics from 2013, 2018 and 2020. And still it isn't included in any of the many releases since then. It might be complicated, but that doesn't mean it should be pushed forward that long.
Anyway, if a post is quite old, and replies have died out over the years, I don't think it is that bad to create a new one. Also, it isn't always that easy for everyone to ask the right questions when in need of an answer. The recent "refurbishement" of the GS forum makes it even harder for me to find what I am looking for.
Josh,
Have you marked my previous comment as a "solution"?! Not sure if this is the best way to go! You are right if you hope more people find their way to this comment and ask GS to just do this for AC26. So Kudos for that!
DGSketcher
Legend
I'm with @Johan Stinckens on this. I am developing a new perspective on some of these wishes. When you look back it is not uncommon to find 10+ year old "important" wishes accompanied by more recent GS apologies for the delay due to complexity. Yet almost overnight GS seem to have been able to adapt AC to be the new tool of choice for structural engineers. We are also hearing from news reports about DDS that AC is probably creating a fully integrated MEP solution. Something isn't right here with regards to Architectural tool development and the users are paying for it.
Johan Stinckens
Very good point @DGSketcher
The Architectural aspect should come first!
Well said!
I've thought for a while that some of the fundamental elements and workflows should be resolved, before developing and releasing new features.
I understand the new features make the software for competitive and useful, but some of these fundamental issues date back years and years.
Steve Jepson
This is not a great example of the important problem being talked about.  The "solution" was to simply model the mesh the way you wanted it,  instead of trying to carve it out using a SEO.
David O
Hi if it is for terrain modelling using the mesh tool why don't you use the terrain tool pallet, this helps you work with levelling areas and also does cut & fill calcs, it is real easy to use, I have attached a couple of screen grabs for you.
That must be a paid Add-On as there is no such tool by default in Archicad.
David O
Hi Laszio
It's not if you have a current Graphisoft UAS subscription it's part of the UAS, if you go to your help menu then select UAS downloads there are some very useful tools there that I use all the time.
There are also useful additional libraries an extended materials lib for Cineware in Archicad for rendering & the goodies which extend some of the tools of Archicad, I have attached a couple of screen grabs to show you.
Regards
David
Graphisoft UAS downloads terrain tool.jpgArchicad UAS command under help.jpgSpecial tools for Archicad under UAS.jpg
Status
Submitted
with 118 Votes
Wish details
