2023-11-21 04:52 PM - last edited on 2024-08-06 03:48 PM by Laszlo Nagy
I did the installation and copied the folders to the correct place (the sd.webui in C and the Add on to the Archicad folder).
But when starting Archicad 27 opening the AI Visualizer from the Palettes and clicking on Generate, I get this error about the AI server:
What is this and how to make it work normally?
Thank you in advance.
2023-11-21 09:59 PM
Hi!
Unfortunately, I'm having the same issue and cannot get past it.
2023-11-21 10:56 PM
Me too...same problem
2023-11-21 11:21 PM
I tried everything and eventually got mine to work.
Below are the three changes I made that worked for me.
I changed the AI Engine address to 127.0.0.1:7860
I ran the runHighVram file as an administrator ( in the sd.webui folder)
Finally, I disabled my Intel graphics card in my device manager.
That worked for me, I hope it helps you.
2023-11-22 07:48 AM
Thats not working for me.
2023-11-22 07:52 AM - edited 2023-11-22 07:53 AM
This probably works for NVIDIA graphic cards only. Doesnt work on Radeon or Intel
2023-11-22 10:12 AM
Is this really the case?
2023-11-22 11:36 AM
Is there any way to specify the GPU - there must be a setting somewhere (instead of disabling the Intel-onboard card).
Or???
2023-11-22 11:43 AM
Like I said that worked for me.
Have you tried running Archicad as administrator?
2023-11-22 03:54 PM - last edited on 2024-08-06 03:49 PM by Laszlo Nagy
I did run it as admin and nothing changed. The same error pops up when clicking on Generate.
I also clicked "Start AI Engine" and this is the window that opens:
What should be done?
