Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
Error code 128
Piscator
Does not work for me on M1 pro.
Terminal says error code 128.
Norbert Kucsma
Hi Piscator,
Thanks for the report.
Can you please check if the installation was successful? Did you face any errors in the process?
Please send us the content of the whole Terminal window (Shell, Export text as).
Thank you,
Norbert Kucsma
Technical Support Engineer
I ran the run.sh again, now it works. thanks!
