Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
Error code 128
Piscator
Does not work for me on M1 pro.
Terminal says error code 128.
Norbert Kucsma
Hi Piscator,
Thanks for the report.
Can you please check if the installation was successful? Did you face any errors in the process?
Please send us the content of the whole Terminal window (Shell, Export text as).
Thank you,
Norbert Kucsma
Technical Support Engineer
Norbert Kucsma
Hi Piscator,
Thank you,
Norbert Kucsma
I ran the run.sh again, now it works. thanks!
