Archicad C++ API
AC18 DevKits are available
Akos Somorjai
Hi fellow developers,
The ArchiCAD 18 API development kits are available in the download area. Don't forget to read the New Features Guide
Good luck,
Ɓkos
27 REPLIES 27
Hi
Is the ODBC Driver build dependent. Can't seem to get it to connect to 4020 (Driver 3006) plans.? If so when would we expect to see this updated?
Gorazd
Any info on AC19 DevKits? When they will be available?
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
As far as I remember DevKits become available a bit after the version is released.
I suppose this will happen similarly this year as well.
saifudin F
dear sir the API Development Kit is already now available if you like & have access you can get it šŸ˜‰
Thanks, saifudein F. Yes, the 19 kit downloads are shown as being posted last Friday:
https://partner.graphisoft.com/developers/default.aspx?RootFolder=%2fdevelopers%2fDownloads%2fARCHIC...
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
The partner site of Graphisoft is not accessible by mere mortals like us.
Are developers considered partners? DO they have access?
Oops. I didn't notice it was a secure site since I appear to be permanently logged in. As far as I know, developers have access to that site...
stefan
You need to have a developer account, for which registration is required. The AC19 Devkit is available there (as are the other Devkits). This is, AFAIK, the only place where they are distributed.
Archicad-user since 1998
my Archicad Book
