Archicad C++ API
C++\Archi27 API How To Loop Addoon Gloval Values In Menu when Menu Exist
nishida_jp
visual studio c++2017
Archi27 API
Programing
struct GlovalValues;
static GSErrCode MenuCommandHandler (const API_MenuParams *menuParams)
switch (menuParams->menuItemRef.menuResID) {
case ID_ADDON_MENU01:
   // addon programing By globalValues
  break;
return 0;
I select menu on ID_ADDON_MENU01.
after ID_ADDON_MENU01
but GlovalValues initialized on next select menu ;
how to continue data of GlovalValues on next menu pushed;
LChen
I'd like suggest you to use ACAPI_SetPreferences() and ACAPI_GetPreferences() function to keep and restore your own data in your project file. Please check the details in API Doc.
HTH.
1 REPLY 1
LChen
HTH.
