2014-01-24 04:13 PM - last edited on 2023-08-01 04:36 PM by Doreena Deng
2014-01-25 10:06 AM
void changeWall(const API_Guid* ArchAPIGUID){ API_Element element, mask; API_Coord c1, c2; GSErrCode err = NoError; double height; double width; BNZeroMemory (&element, sizeof (API_Element)); API_Guid currAPIGuid = *ArchAPIGUID; element.header.guid = currAPIGuid; err = ACAPI_Element_Get (&element); if (err != NoError) DBPrintf("hiba"); c1 = element.wall.begC; c2 = element.wall.endC; height = element.wall.height; width = element.wall.thickness; DBPrintf("width XXXXXX %d", width); if (err == NoError) { ACAPI_ELEMENT_MASK_CLEAR (mask); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, begC); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, endC); //ACAPI_ELEMENT_MASK_SET (mask, API_WallType, height); //ACAPI_ELEMENT_MASK_SET (mask, API_WallType, thickness); element.wall.begC = c2; element.wall.endC = c1; //element.wall.height = 100*height; //element.wall.thickness = width; err = ACAPI_Element_Change (&element, &mask, NULL, 0, true); if (err == NoError) { DBPrintf("Fal megvan"); err = ACAPI_Element_Get (&element); width = element.wall.thickness; DBPrintf("width YYYYYY %d", width); } } } //getelements void getElements (void) { API_Quantity quantity, mask; API_Quantities quantities; API_QuantityPar params; GSErrCode err; GS::Array<API_Guid> elemList; ACAPI_Element_GetElemList(API_WallID,&elemList); ACAPI_ELEMENT_QUANTITY_MASK_CLEAR (mask); ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface1); ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface2); ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, volume); quantities.quantityData = &quantity; params.minOpeningSize = EPS; DBPrintf ("number of walls = %ld,", elemList.GetSize ()); short visible = 0; short onStory = 0; short inView = 0; for (GS::Array<API_Guid>::ConstIterator it = elemList.Enumerate (); it != NULL; ++it) { if (ACAPI_Element_Filter (*it, APIFilt_OnVisLayer)) ++visible; if (ACAPI_Element_Filter (*it, APIFilt_OnActFloor)) ++onStory; if (ACAPI_Element_Filter (*it, APIFilt_InCroppedView)) ++inView; //get quantities err = ACAPI_Element_GetQuantities (*it, ¶ms, &quantities, &mask); if (err == NoError) { DBPrintf ("surface1: %.2lf surface2: %.2lf volume: %.2lf", quantity.wall.surface1, quantity.wall.surface2, quantity.wall.volume); } changeWall(&it.GetCurrent()); } //DBPrintf ("%d visible, %d on the view\'s floor, %d in the cropped view\n", visible, onStory, inView); }
2014-01-27 11:21 AM
void changeWall (const API_Guid* ArchAPIGUID) { API_Element element, mask; API_Coord c1, c2; GSErrCode err = NoError; double height; double width; BNZeroMemory (&element, sizeof (API_Element)); API_Guid currAPIGuid = *ArchAPIGUID; element.header.guid = currAPIGuid; err = ACAPI_Element_Get (&element); if (err != NoError) DBPrintf("hiba"); c1 = element.wall.begC; c2 = element.wall.endC; height = element.wall.height; width = element.wall.thickness; DBPrintf("width XXXXXX %d", width); if (err == NoError) { ACAPI_ELEMENT_MASK_CLEAR (mask); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, begC); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, endC); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, height); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, thickness); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, thickness1); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, type); element.wall.begC = c2; element.wall.endC = c1; element.wall.height = height*2; element.wall.thickness = width*2; element.wall.thickness1 = width*2; element.wall.type = APIWtyp_Trapez; err = ACAPI_Element_Change (&element, &mask, NULL, 0, true); if (err == NoError) { DBPrintf("Fal megvan"); err = ACAPI_Element_Get (&element); width = element.wall.thickness; DBPrintf("width YYYYYY %d", width); } } }
2014-01-27 08:07 PM
err = ACAPI_Database(APIDb_ChangeCurrentDatabaseID, &element.detail.databaseID); if(err == NoError){ } else { DBPrintf("%d",(Int32)err); }What could be the problem?
2014-01-28 09:47 AM
2014-01-29 01:24 AM
AndorSzamos wrote:Are you bounding this operation with
It gives me the error: APIERR_REFUSEDCMD.
2014-01-29 08:47 AM
#include "APIEnvir.h" // ---------------------------------- Includes --------------------------------- #include <math.h> #include <string.h> #include "ACAPinc.h" // also includes APIdefs.h //#include "Model.hpp" #include "APICommon.h" #include "DGModule.hpp" #include "DG.h" #include "MDIDs_APICD.h" //non-AC #include <iostream> #include <fstream> #include <string> //program includes // ---------------------------------- Types ------------------------------------ #define EvaluateButton 1 #define CancelButton 2 #define UserArea 3 #define Consumption1 5 #define Consumption2 7 using namespace std; // ---------------------------------- Variables -------------------------------- // ---------------------------------- Prototypes ------------------------------- // ============================================================================= // // Dialog control functions // // ============================================================================= void doEvaluation(void){ DBPrintf("bla"); } // ----------------------------------------------------------------------------- // Main dialog callback function // ----------------------------------------------------------------------------- static short DGCALLBACK DialogMessageHandler (short message, short dialId, short itemId, DGUserData userData, DGMessageData msgData) { UNUSED_PARAMETER (msgData); UNUSED_PARAMETER (dialId); UNUSED_PARAMETER (userData); //INNEN FOLYTASD A GOMBOKRA A REAGALAST switch (message) { case DG_MSG_CLOSE: break; case DG_MSG_CLICK: switch (itemId) { //case 2: // Close button case EvaluateButton: doEvaluation(); break; case CancelButton: return(1); break; default: return(1); break; } default: break; } return 0; } // DialogMessageHandler // ============================================================================= // // Main functions // // ============================================================================= #ifdef __APPLE__ #pragma mark - #endif // ----------------------------------------------------------------------------- // Call the list data dialog // ----------------------------------------------------------------------------- //------------------------------------------------------------------------------ // Get Element properties 2 //------------------------------------------------------------------------------ //change properties void changeWall (const API_Guid* ArchAPIGUID) { API_Element element, mask; API_Coord c1, c2; GSErrCode err = NoError; double height; double width; BNZeroMemory (&element, sizeof (API_Element)); API_Guid currAPIGuid = *ArchAPIGUID; element.header.guid = currAPIGuid; err = ACAPI_Element_Get (&element); if (err != NoError) DBPrintf("hiba"); c1 = element.wall.begC; c2 = element.wall.endC; height = element.wall.height; width = element.wall.thickness; DBPrintf("width XXXXXX %d", width); if (err == NoError) { //we need to change the database we are working with to the current database of the current element err = ACAPI_Database(APIDb_ChangeCurrentDatabaseID, &element.detail.databaseID); if(err == NoError){ } else { DBPrintf("%d",(Int32)err); } ACAPI_ELEMENT_MASK_CLEAR (mask); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, begC); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, endC); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, height); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, thickness); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, thickness1); ACAPI_ELEMENT_MASK_SET (mask, API_WallType, type); element.wall.begC = c2; element.wall.endC = c1; element.wall.height = height*2; element.wall.thickness = width*2; element.wall.thickness1 = width*2; element.wall.type = APIWtyp_Trapez; err = ACAPI_Element_Change (&element, &mask, NULL, 0, true); if (err == NoError) { DBPrintf("Fal megvan"); } else{ DBPrintf("%d",(Int32)err); } err = ACAPI_Element_Get (&element); width = element.wall.thickness; DBPrintf("width YYYYYY %d", width); } } void getElements (void) { API_Quantity quantity, mask; API_Quantities quantities; API_QuantityPar params; GSErrCode err; GS::Array<API_Guid> elemList; ACAPI_Element_GetElemList(API_WallID,&elemList); ACAPI_ELEMENT_QUANTITY_MASK_CLEAR (mask); ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface1); ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface2); ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, volume); quantities.quantityData = &quantity; params.minOpeningSize = EPS; DBPrintf ("number of walls = %ld,", elemList.GetSize ()); short visible = 0; short onStory = 0; short inView = 0; for (GS::Array<API_Guid>::ConstIterator it = elemList.Enumerate (); it != NULL; ++it) { if (ACAPI_Element_Filter (*it, APIFilt_OnVisLayer)) ++visible; if (ACAPI_Element_Filter (*it, APIFilt_OnActFloor)) ++onStory; if (ACAPI_Element_Filter (*it, APIFilt_InCroppedView)) ++inView; //get quantities err = ACAPI_Element_GetQuantities (*it, ¶ms, &quantities, &mask); if (err == NoError) { DBPrintf ("surface1: %.2lf surface2: %.2lf volume: %.2lf", quantity.wall.surface1, quantity.wall.surface2, quantity.wall.volume); } changeWall(&it.GetCurrent()); } //DBPrintf ("%d visible, %d on the view\'s floor, %d in the cropped view\n", visible, onStory, inView); } static void Evaluate (void) { API_ListData param; GSResModule saveResModule; BNZeroMemory (¶m, sizeof (param)); param.header.setIndex = 1; param.header.typeID = API_ComponentID; saveResModule = ACAPI_UseOwnResModule (); DGModalDialog (32510, DialogMessageHandler, (DGUserData) (¶m)); ACAPI_ResetResModule (saveResModule); getElements(); return; } //Evaluate // ----------------------------------------------------------------------------- // MenuCommandHandler // called to perform the user-asked command // ----------------------------------------------------------------------------- GSErrCode __ACENV_CALL MenuCommandHandler (const API_MenuParams *params) { UNUSED_PARAMETER (params); Evaluate (); return NoError; } // DoCommand // ============================================================================= // // Required functions // // ============================================================================= //------------------------------------------------------ // Dependency definitions //------------------------------------------------------ API_AddonType __ACENV_CALL CheckEnvironment (API_EnvirParams* envir) { if (envir->serverInfo.serverApplication != APIAppl_ArchiCADID) return APIAddon_DontRegister; GSResModule saveResModule = ACAPI_UseOwnResModule (); ACAPI_Resource_GetLocStr (envir->addOnInfo.name, 32000, 1); ACAPI_Resource_GetLocStr (envir->addOnInfo.description, 32000, 2); ACAPI_ResetResModule (saveResModule); return APIAddon_Normal; } /* CheckEnvironment */ //------------------------------------------------------ // Interface definitions //------------------------------------------------------ GSErrCode __ACENV_CALL RegisterInterface (void) { ACAPI_Register_Menu (32500, 0, MenuCode_DocExtras, MenuFlag_Default); return NoError; } /* RegisterInterface */ //------------------------------------------------------ // Called when the Add-On has been loaded into memory // to perform an operation //------------------------------------------------------ GSErrCode __ACENV_CALL Initialize (void) { GSErrCode err = ACAPI_Install_MenuHandler (32500, MenuCommandHandler); if (err != NoError) DBPrintf ("Energy-Budget Evaluator:: Initialize() ACAPI_Install_MenuHandler failed\n"); return err; } /* Initialize */ // ----------------------------------------------------------------------------- // FreeData // called when the Add-On is going to be unloaded // ----------------------------------------------------------------------------- GSErrCode __ACENV_CALL FreeData (void) { return NoError; }
2014-01-29 10:09 AM
GSErrCode __ACENV_CALL MenuCommandHandler (const API_MenuParams *menuParams) { UNUSED_PARAMETER (params); GSErrCode err = ACAPI_OpenUndoableSession ("Undo changes"); if (err != NoError) { DBPrintf ("MenuCommandHandler cannot open undoable session: %d\n", err); return err; } Evaluate (); ACAPI_CloseUndoableSession (); return NoError; } // DoCommand
2014-01-29 10:37 AM
