2014-01-24
04:13 PM
2023-08-01
04:36 PM
Doreena Deng
2014-01-25 10:06 AM
void changeWall(const API_Guid* ArchAPIGUID){
API_Element element, mask;
API_Coord c1, c2;
GSErrCode err = NoError;
double height;
double width;
BNZeroMemory (&element, sizeof (API_Element));
API_Guid currAPIGuid = *ArchAPIGUID;
element.header.guid = currAPIGuid;
err = ACAPI_Element_Get (&element);
if (err != NoError)
DBPrintf("hiba");
c1 = element.wall.begC;
c2 = element.wall.endC;
height = element.wall.height;
width = element.wall.thickness;
DBPrintf("width XXXXXX %d", width);
if (err == NoError) {
ACAPI_ELEMENT_MASK_CLEAR (mask);
ACAPI_ELEMENT_MASK_SET (mask, API_WallType, begC);
ACAPI_ELEMENT_MASK_SET (mask, API_WallType, endC);
//ACAPI_ELEMENT_MASK_SET (mask, API_WallType, height);
//ACAPI_ELEMENT_MASK_SET (mask, API_WallType, thickness);
element.wall.begC = c2;
element.wall.endC = c1;
//element.wall.height = 100*height;
//element.wall.thickness = width;
err = ACAPI_Element_Change (&element, &mask, NULL, 0, true);
DBPrintf("Fal megvan");
DBPrintf("width YYYYYY %d", width);
//getelements
void getElements (void)
API_Quantity quantity, mask;
API_Quantities quantities;
API_QuantityPar params;
GSErrCode err;
GS::Array<API_Guid> elemList;
ACAPI_Element_GetElemList(API_WallID,&elemList);
ACAPI_ELEMENT_QUANTITY_MASK_CLEAR (mask);
ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface1);
ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, surface2);
ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, wall, volume);
quantities.quantityData = &quantity;
params.minOpeningSize = EPS;
DBPrintf ("number of walls = %ld,", elemList.GetSize ());
short visible = 0;
short onStory = 0;
short inView = 0;
for (GS::Array<API_Guid>::ConstIterator it = elemList.Enumerate (); it != NULL; ++it) {
if (ACAPI_Element_Filter (*it, APIFilt_OnVisLayer))
++visible;
if (ACAPI_Element_Filter (*it, APIFilt_OnActFloor))
++onStory;
if (ACAPI_Element_Filter (*it, APIFilt_InCroppedView))
++inView;
//get quantities
err = ACAPI_Element_GetQuantities (*it, ¶ms, &quantities, &mask);
DBPrintf ("surface1: %.2lf surface2: %.2lf volume: %.2lf", quantity.wall.surface1, quantity.wall.surface2, quantity.wall.volume);
changeWall(&it.GetCurrent());
//DBPrintf ("%d visible, %d on the view\'s floor, %d in the cropped view\n", visible, onStory, inView);
2014-01-27 11:21 AM
void changeWall (const API_Guid* ArchAPIGUID)
API_Coord c1, c2;
double height;
double width;
if (err != NoError)
DBPrintf("hiba");
ACAPI_ELEMENT_MASK_SET (mask, API_WallType, thickness1);
ACAPI_ELEMENT_MASK_SET (mask, API_WallType, type);
element.wall.height = height*2;
element.wall.thickness = width*2;
element.wall.thickness1 = width*2;
element.wall.type = APIWtyp_Trapez;
} 2014-01-27 08:07 PM
err = ACAPI_Database(APIDb_ChangeCurrentDatabaseID, &element.detail.databaseID);
if(err == NoError){
else {
DBPrintf("%d",(Int32)err);
What could be the problem?
2014-01-28 09:47 AM
2014-01-29 01:24 AM
AndorSzamos wrote:Are you bounding this operation with
It gives me the error: APIERR_REFUSEDCMD.
2014-01-29 08:47 AM
#include "APIEnvir.h"
// ---------------------------------- Includes ---------------------------------
#include <math.h>
#include <string.h>
#include "ACAPinc.h" // also includes APIdefs.h
//#include "Model.hpp"
#include "APICommon.h"
#include "DGModule.hpp"
#include "DG.h"
#include "MDIDs_APICD.h"
//non-AC
#include <iostream>
#include <fstream>
#include <string>
//program includes
// ---------------------------------- Types ------------------------------------
#define EvaluateButton 1
#define CancelButton 2
#define UserArea 3
#define Consumption1 5
#define Consumption2 7
using namespace std;
// ---------------------------------- Variables --------------------------------
// ---------------------------------- Prototypes -------------------------------
// Dialog control functions
void doEvaluation(void){
DBPrintf("bla");
// Main dialog callback function
static short DGCALLBACK DialogMessageHandler (short message,
short dialId,
short itemId,
DGUserData userData,
DGMessageData msgData)
UNUSED_PARAMETER (msgData);
UNUSED_PARAMETER (dialId);
UNUSED_PARAMETER (userData);
//INNEN FOLYTASD A GOMBOKRA A REAGALAST
switch (message) {
case DG_MSG_CLOSE:
break;
case DG_MSG_CLICK:
switch (itemId) {
//case 2: // Close button
case EvaluateButton:
doEvaluation();
break;
case CancelButton:
return(1);
break;
default:
return(1);
break;
default:
break;
return 0;
} // DialogMessageHandler
// Main functions
#ifdef __APPLE__
#pragma mark -
#endif
// Call the list data dialog
// Get Element properties 2
//change properties
API_Coord c1, c2;
double height;
double width;
if (err != NoError)
DBPrintf("hiba");
//we need to change the database we are working with to the current database of the current element
if(err == NoError){
else {
else{
GSErrCode err;
short visible = 0;
short onStory = 0;
short inView = 0;
++visible;
++onStory;
++inView;
//get quantities
static void Evaluate (void)
API_ListData param;
GSResModule saveResModule;
BNZeroMemory (¶m, sizeof (param));
param.header.setIndex = 1;
param.header.typeID = API_ComponentID;
saveResModule = ACAPI_UseOwnResModule ();
DGModalDialog (32510, DialogMessageHandler, (DGUserData) (¶m));
ACAPI_ResetResModule (saveResModule);
getElements();
return;
} //Evaluate
// MenuCommandHandler
// called to perform the user-asked command
GSErrCode __ACENV_CALL MenuCommandHandler (const API_MenuParams *params)
UNUSED_PARAMETER (params);
Evaluate ();
return NoError;
} // DoCommand
// Required functions
// Dependency definitions
API_AddonType __ACENV_CALL CheckEnvironment (API_EnvirParams* envir)
if (envir->serverInfo.serverApplication != APIAppl_ArchiCADID)
return APIAddon_DontRegister;
GSResModule saveResModule = ACAPI_UseOwnResModule ();
ACAPI_Resource_GetLocStr (envir->addOnInfo.name, 32000, 1);
ACAPI_Resource_GetLocStr (envir->addOnInfo.description, 32000, 2);
return APIAddon_Normal;
} /* CheckEnvironment */
// Interface definitions
GSErrCode __ACENV_CALL RegisterInterface (void)
ACAPI_Register_Menu (32500, 0, MenuCode_DocExtras, MenuFlag_Default);
return NoError;
} /* RegisterInterface */
// Called when the Add-On has been loaded into memory
// to perform an operation
GSErrCode __ACENV_CALL Initialize (void)
GSErrCode err = ACAPI_Install_MenuHandler (32500, MenuCommandHandler);
if (err != NoError)
DBPrintf ("Energy-Budget Evaluator:: Initialize() ACAPI_Install_MenuHandler failed\n");
return err;
} /* Initialize */
// FreeData
// called when the Add-On is going to be unloaded
GSErrCode __ACENV_CALL FreeData (void)
return NoError;
2014-01-29 10:09 AM
GSErrCode __ACENV_CALL MenuCommandHandler (const API_MenuParams *menuParams)
GSErrCode err = ACAPI_OpenUndoableSession ("Undo changes");
if (err != NoError) {
DBPrintf ("MenuCommandHandler cannot open undoable session: %d\n", err);
return err;
Evaluate ();
ACAPI_CloseUndoableSession ();
return NoError;
} // DoCommand 2014-01-29 10:37 AM
