JeffH
Drawing Title View ID
I am trying to create a single company specific Drawing Title that meets all of our wants, and have run into a bit of a wall.
with the drawing tool, Archicad allows you to adjust the Drawing ID to be "by layout", "By View ID" & By Custom.
this appears to be using the autotext "Drawing ID"
while trying to create a this drawing title I am struggling to figure out how to differentiate the auto text so that I can have the bubble text read the specific layout while also having smaller grayscale text after the "wall section" drawing name that shows the drawing ID.
I guess I am trying to figure out how or where the view ID+Name script pulls the ID, that differentiates itself from the By Layout/By View ID/Custom toggle.
Ultimately, this is what I am trying to have the Drawing Title look like, but havent be able to get the "A5" & "WS-01" to act independently from each other
AC24 / AC26 / AC27
Win10
2 Replies 2
AllanP
you will need to change the code:
this is where it can get the layout name/layout ID
REQUEST ("HomeDB_info", "", homeDBIntId, homeDBUserId, homeDBName, homeContext)
Returns in the given variables the internal ID (integer), the user ID and name (strings) of the home database (where the library part containing
this request was placed).
• if placed on a layout: the layout internal ID, number and name, homeContext = 5.
For labels the returned data refers to the labeled element. The collected data can be used
i.e.
n = request ("HomeDB_info", "", layout_unique_ID, AC_LayoutNumber, AC_LayoutName, layout_home_context)
then you can use the fields
AC_LayoutNumber
AC_LayoutName
the "AC_DrawingName" is the drawing name, this needs to be a parameter in the parameters list to work, it auto populates.
the AC_DrawingNumber" is the drawing number, this needs to be a parameter in the parameters list to work, it auto populates.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
Lingwisyer
Guru
Given this is in the Documentation sub and the provided labels, I am assuming this is an in-the-box drawing title? If so, please provide information regarding your localisation as library parts may vary.
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
