We value your input!
Archicad C++ API
Get object's parameter description (not just name)
Miha Nahtigal
HI everyone. I am looking for a way to get a parameter description from a placed GSM object.
I can get parameter's name with
const API_AddParType& parameter = (*memo.params)[ii];
GS::UniString ParameterName = parameter.name;
but the values of "valueDescription" or "uDescname" of  the struct API_AddParType
are always empty. Is there another way?
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
LChen
I'd suggest you to use ACAPI_LibraryPart_GetParams() to get parameter description.
HTH.
LChen
HTH.
Miha Nahtigal
Thanks, that worked fine.
