Tuesday
- last edited
Friday
Hello @All,
I am new to C++ and the ArchiCAD API in general.
I've been learning how to create a .sln file from a CmakeList.txt following the instructions I've found in our group. Honestly, I've followed the steps closely, but still can't manage to build the final product, which is the add-on .apx file. I have some questions and really need your help:
What should I do to fix this error, or how can I build the Archicad add-on project?
Of course, I am still trying to resolve these two issues I've asked you about, but if I could get more help from you, I would really appreciate it.
Thank you!
Solved! Go to Solution.
Tuesday - last edited Tuesday
I recommend using this as a starting point:
Now we have a python script that does all the steps above.
Tuesday
hehey pphamt.
Just to be clear, when you are at step 9, you where succsessfull in creating the *.sln correct?
Best Regards
Joel
Wednesday
Hi Joel Buehler,
Wednesday
Hi Viktor Kovacs,
Thanks for your support
Wednesday
Very cool.
I recommend you link the blog of the developer site to this knowlege base. information is now kinda all over the place.
https://archicadapi.graphisoft.com/getting-started-with-archicad-add-ons
VS
