2004-05-15 12:33 AM - last edited on 2022-12-13 09:56 PM by Daniel Kassai
2004-05-17 06:47 PM
const char* networkFileLocation = "Public:CAD_Standards:KA-Update:KA-Add-On"; const char* localFileLocation = "Local_Disk:Applications:ArchiCAD 8.1 folder:Add-Ons:KA:KA-Add-On"; // define Location objects IO::Location networkFile (networkFileLocation); IO::Location localFile (localFileLocation); GSErrCode err; GSErrCode err2; // temporary to help track down delete failure err = IO::fileSystem.Copy (networkFile, localFile); if (err == IO::Folder::SourceNotFound) { char msgStr[256]; CHCopyC ("Error, Source not found", msgStr); ACAPI_WriteReport (msgStr, false); } else if (err == IO::Folder::TargetExists) { err2 = IO::fileSystem.Delete(localFile); if (err2) { char msgStr[256]; CHCopyC ("Delete Failed", msgStr); ACAPI_WriteReport (msgStr, false); return; } IO::fileSystem.Copy(networkFile, localFile); char msgStr[256]; CHCopyC ("Updated from source", msgStr); ACAPI_WriteReport (msgStr, false); } return;I cannot figure out while I keep getting the "Delete failed" message, and the Delete function fails. I suspect that is may have to do with the mixture of fileSystem and Folder namespaces/object behavior.
2004-05-20 04:28 PM
2004-05-20 04:57 PM
What you can do is use a separate Add-On, which does nothing else just updates your original Add-On. Just make sure first that the original Add-On is already unloaded.Wow, you read my mind.
