Archicad C++ API
RINT STR#
Curtis ZONDO
Hello everybody. I want to know what do those things means in the RINT folder
... ES^EE^EI^ED^EL"..
2 ACCEPTED SOLUTIONS
Miha Nahtigal
These are control codes for menu items that control if menu item will be enabled/disabled in specified view (floorplan/section/elevation,..)
I think the definitions were in API Devkit 26  but dissapeared in newer devkits.
https://community.graphisoft.com/t5/Archicad-C-API/First-add-on-questions/td-p/260922
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
Archicad 28 C++ API: Required Resources
This is the link to the definitions 🙂
Miha Nahtigal
Thanks for your answer
