4 weeks ago - last edited 3 weeks ago by Laszlo Nagy
Hi
We have build 2 examples files in the SDK 28.200. Each time we add the generated files to Achicad, we got a message "This add-on cannot be validated" in the add-on manager.
Could you please confirm that if you build the apx via the cmake, it does work in the Archicad 28 technology preview.
Also, a little remark, on the website you mention that the SDK is version 28.300 and on the website the latest SDK available for download is 28.2000.
Solved! Go to Solution.
3 weeks ago
Could you check whether you've generated your proper Developer/API Local ID and added in xxxFix.grc file?
HTH.
4 weeks ago
Could you load the 2 example .apxs with Archicad28 demo mode?
(run Archicad.exe -DEMO)
HTH.
The error still remains...
3 weeks ago
HTH.
