3 weeks ago - last edited 3 weeks ago by Laszlo Nagy
Hi.
I want to get Grid Name and Position Information.
i use ACAPI_LibraryPart_GetActParameters, but it show only "AC_MarkerText_1"'s default value. (Example X1)
I would appreciate any help you can give me.
I use Archicad 27 API
API_GetParamsType getParams;
BNZeroMemory(&getParams, sizeof(API_GetParamsType));
err = ACAPI_LibraryPart_GetActParameters(&getParams);
if (err == NoError) {
for (Int32 i = 0; i < BMGetHandleSize((GSHandle)getParams.params) / sizeof(API_AddParType); ++i) {
const API_AddParType& param = (*getParams.params)[i];
if (strcmp(param.name, "AC_MarkerText_1") == 0) {
//info.markerText = reinterpret_cast<const char*>(param.value.uStr);
info.markerText = GS::UniString(param.value.uStr).ToCStr().Get();
DBPrintf("Marker Text: %s\n", info.markerText.c_str());
break;
a week ago
Hi, I'd suggest you to use ACAPI_Element_GetMemo() to get "AC_MarkerText_1" and "AC_Length" values from memo.params in this case.
I think the position information would be element.object.pos and the end node of
