‎2023-01-23 05:47 AM
As per the link below, I have installed the latest version of python.
I've then opened Archicad 26 (also 25), gone into the Work Environment > More options and enabled the python palette under experimental features.
When I navigate to Window > Palettes, the Python palette does not show.
Have closed and opened AC but get same result.
Any suggestions?
Solved! Go to Solution.
‎2023-05-16 04:18 PM - edited ‎2024-05-01 11:26 AM
I had the same problem with AC 25 and AC26.
To show the palette I had to add it manually in the Work Environment / Management - Pallets. See screenshot below (Swiss version):
‎2023-01-23 12:36 PM
check your Work Environment
‎2023-01-23 12:59 PM
Python palette is usually at the very bottom of the list . Did you double check that it hasn't scrolled off the screen? Also check that Python,exe is in your Path?
‎2023-01-31 01:40 PM
Do you have SSA/Forward? This page says it is feature that is part of the Forward offering:
https://graphisoft.com/forward
‎2024-04-04 04:07 AM
I must have put the above on the back burner and forgot about it.
I tried again today in AC27 and got same issue (Enabled palette under experimental features).
Manually adding the Python Palette option to the Menu worked thou.
