Archicad Python API
About automating tasks in Archicad using the Python API.
Python Palette not showing
Josh Verran
As per the link below, I have installed the latest version of python.
I've then opened Archicad 26 (also 25), gone into the Work Environment > More options and enabled the python palette under experimental features.
When I navigate to Window > Palettes, the Python palette does not show.
Have closed and opened AC but get same result.
Any suggestions?
https://community.graphisoft.com/t5/Project-Management-articles/Python-Connection-in-Archicad/ta-p/3...
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
PeterPetersen
I had the same problem with AC 25 and AC26.
To show the palette I had to add it manually in the Work Environment / Management - Pallets. See screenshot below (Swiss version):
5 REPLIES 5
Djordje
check your Work Environment
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
poco2013
Mentor
Python palette is usually at the very bottom of the list . Did you double check that it hasn't scrolled off the screen? Also check that Python,exe is in your Path?
Gerry
Do you have SSA/Forward? This page says it is feature that is part of the Forward offering:
https://graphisoft.com/forward
PeterPetersen
Josh Verran
I must have put the above on the back burner and forgot about it.
I tried again today in AC27 and got same issue (Enabled palette under experimental features).
Manually adding the Python Palette option to the Menu worked thou.
