ā2014-08-05
12:02 PM
ā2023-05-09
03:36 PM
Noemi Balogh
ā2014-08-05 01:07 PM
bestordu wrote:A few ideas:
Hi everyone;
I have a problem about Archicad 18 Bimx. My problem is; Bimx dial command is not active in 3D drawing screen. I can't transfer modellings to BIMx. I'm adding a photo-down menu on the state. Thank you in advance for your help.
ā2014-08-05 04:44 PM
Marton wrote:Marton Kiss, Thank you for the answer first. You're right. I did what you say and status of the "Add-Ons menus is;bestordu wrote:A few ideas:
Hi everyone;
- verify that the BIMx Add-On has been installed correctly: C:\Program Files\GRAPHISOFT\ArchiCAD 18\Add-Ons\BIMx\BIMx.apx
- verify that in Add-On Manager (Option menu) it is not disabled
- if both of these appear to be good re-run the ArchiCAD installer, which will run in repair mode
Let me know the results,
Marton
ā2014-08-06 03:15 AM
ā2014-08-06 07:10 AM
Barry wrote:Ok than, I'll apply what you says and I will give information about the situation. Thank you for your answer Barry.
First I would check your Work Environment - make sure you have the default 'Standard" WE applied.
Also when you select it in the Add-on Manager list what does it say in the 'Add-on Info' section?
Then if that doesn't work try re-running the Archicad installer which as Martin said will run in repair mode.
This should fix the BIMx add-on as it is part of Archicad now.
If that doesn't work then I would un-install and re-install completely.
If that doesn't work then post back here or ideally contact you Archicad support person.
ā2014-08-06 07:46 AM
bestordu wrote:I uninstall the program and re-installed. but the problem still exists. Add-Ons info of BIMx is: "Error while checking the environment" =/Barry wrote:Ok than, I'll apply what you says and I will give information about the situation. Thank you for your answer Barry.
ā2014-08-06 03:58 PM
bestordu wrote:Please start the BIMx.exe from the same folder. When it starts up does it show the type of license you have (e.g: commercial, educational)?
ā2014-08-07 07:57 AM
Marton wrote:Thank you for your answer, marton. I have Network License Key and my network license is runnig like that screen-shot:bestordu wrote:Please start the BIMx.exe from the same folder. When it starts up does it show the type of license you have (e.g: commercial, educational)?
I have a feeling that somehow it cannot locate your ArchiCAD license, that also drives BIMx. Do you have a local or a network license key for ArchiCAD?
Marton
ā2014-08-12 01:14 PM
bestordu wrote:Marton wrote:Thank you for your answer, marton. I have Network License Key and my network license is runnig like that screen-shot:bestordu wrote:Please start the BIMx.exe from the same folder. When it starts up does it show the type of license you have (e.g: commercial, educational)?
Marton
ā2014-08-31 09:52 PM
