We value your input!
BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
ArchiCAD 18 Bimx Problem
Hi everyone;
I have a problem about Archicad 18 Bimx. My problem is; Bimx dial command is not active in 3D drawing screen. I can't transfer modellings to BIMx. I'm adding a photo-down menu on the state. Thank you in advance for your help.
10 REPLIES 10
Marton Kiss
bestordu wrote:
Hi everyone;
A few ideas:
- verify that the BIMx Add-On has been installed correctly: C:\Program Files\GRAPHISOFT\ArchiCAD 18\Add-Ons\BIMx\BIMx.apx
- verify that in Add-On Manager (Option menu) it is not disabled
- if both of these appear to be good re-run the ArchiCAD installer, which will run in repair mode
Let me know the results,
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Marton wrote:
bestordu wrote:
Hi everyone;
A few ideas:
Marton
Marton Kiss, Thank you for the answer first. You're right. I did what you say and status of the "Add-Ons menus is;
How can I fix it?
First I would check your Work Environment - make sure you have the default 'Standard" WE applied.
Also when you select it in the Add-on Manager list what does it say in the 'Add-on Info' section?
Then if that doesn't work try re-running the Archicad installer which as Martin said will run in repair mode.
This should fix the BIMx add-on as it is part of Archicad now.
If that doesn't work then I would un-install and re-install completely.
If that doesn't work then post back here or ideally contact you Archicad support person.
Ok than, I'll apply what you says and I will give information about the situation. Thank you for your answer Barry.
I uninstall the program and re-installed. but the problem still exists. Add-Ons info of BIMx is: "Error while checking the environment" =/
Marton Kiss
Please start the BIMx.exe from the same folder. When it starts up does it show the type of license you have (e.g: commercial, educational)?
I have a feeling that somehow it cannot locate your ArchiCAD license, that also drives BIMx. Do you have a local or a network license key for ArchiCAD?
Marton
Marton Kiss
GRAPHISOFT
Marton
Thank you for your answer, marton. I have Network License Key and my network license is runnig like that screen-shot:
Csaba Kezer
Hi bestordu,
Could you please check if there's a BIMx_Export_Log.txt file in your Documents folder (C:\Users\username\Documents)?
If yes, please send it to me in pm.
Thanks,
Csaba
Marton
Csaba Kézér
Director, Global Customer Support
ok everyone! I solved this problem. I uninstalled and re-installed my antivirus software Eset. Eset...
Thank you very much to everyone for their help.
