BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx - How to "give" someone an .APP file
rob2218
Now that I have created an APP file (*.app) for the BIMx Explorer....how do I "give it" to someone else???
How does another user (or perhaps client) if they have an IPAD get that app file??? so the can view the BIMx model?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
6 REPLIES 6
Just wondering if you ever read the instructions, Rob?
The app is a standalone Mac application. It cannot be opened on an iPad.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
rob2218
you know me Karl...typical "guy" mentality..I don't read anything. Try to "figure it out" as I go along....but I'll read it now.
Also I understand you can save the file out to a *.bimx format where that one you can download and open via email.
i>u
Edgewater, FL!
SOFTWARE VERSION:
The FILE menu has 4 save options as shown in the attached image.
BIMx format is not a self executing file.
You need either the BIMx application on your portable device or the BIMx application that comes with Archicad 15 to open it on any Mac or Window PC.
The Mac and Windows save formats are stand alone self executing files that can only be run on the type of machine they were saved for.
No Archicad or BIMx applications required.
rob2218
Clear and concise...thanks Barry. thank you very much.
i>u
Edgewater, FL!
SOFTWARE VERSION:
RandyC
the "save" as bim-x file
and the "share" options take a Long time before
they show up, Bug?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
What version of Archicad are you using?
Since version 17 BIMx has been built into Archicad so no extra license is needed.
If you can start Archicad you should be able to save as BIMx.
Before that you had to purchase a separate license that was tied to a particular Codemeter/Wibu key license.
I don't use Codemeter borrowed licenses so I can not check the problem.
Maybe someone else that does use a borrowed license can check it out.
