2023-09-21 07:20 PM - last edited on 2023-09-22 05:33 AM by Barry Kelly
I am using AC26 and exported to a BIMx file. The sheets were visible in BIMx and when I tried to open in 3D, this is the message I got:
"This Hyper-model was created in an unsupported version of Archicad. Please install the latest Archicad update and reexport your model. (Error: missing bounding box)"
Not sure what to do, any help?
2024-01-21 04:19 PM
Try sending the model to the BIMx team like Roland is saying in the post above:
https://community.graphisoft.com/t5/BIMx/BIMx-Issues/m-p/399226/highlight/true#M3698
2024-01-22 10:33 AM
Done 🤞
2024-01-22
06:59 PM
2024-01-22
09:31 PM
In case it might be useful to anyone, I finally solved the problem by generating the BIMx file from the "file" drop-down menu, instead of doing it from the publisher.
2024-01-23 04:17 PM
Hi, I'm glad to hear you could export the model properly. It seems the content of 3D View in the Publisher differs from what the Wizard saved.
We want to correct the misleading dialog in BIMx or handle this issue in the export. Therefore, please send the project in .pla format to bimx@graphisoft.com. (Your previous mail arrived, but the linked Hyper-model is no longer available on BIMx Model Transfer.) Thanks!
2024-01-23 04:39 PM
Hi Roland,
Thanks for your quick answer.
File sent.
Kind regards
