2018-12-11
04:35 PM
2023-05-09
02:44 PM
Noemi Balogh
| Archicad 4.55 - 27
Solved! Go to Solution.
2019-02-01 02:08 PM
2018-12-16 08:23 PM
2018-12-21 04:11 PM
| Archicad 4.55 - 27
2018-12-24 10:34 PM
2019-01-07 12:52 PM
Miha_M wrote:Hi,
I have a problem. The "Publish BIMx Hyper-model" option used to do its job. Now it doesn't anymore.
I am logged in, have enough space available on the GS server, but I can't publish my BIMx model anymore.
The command under the "File" Menu is greyed out. If I try "Single file" output, the Publisher lets me publish in PDF only, no other option available. What could be wrong?
2019-01-16 12:40 PM
| Archicad 4.55 - 27
2019-01-31 09:37 AM
dkovacs wrote:Any news? I am moving on to new projects and would need this online publishing option working again,
If these suggestions didn't help, then please go to the Add-on folder of ARCHICAD 22 build 4023and replace the BIMx.apx file with the one I attached. After this, please open ARCHICAD, place a few things, see if it is still greyed out, and then quit ARCHICAD.
This last option shouldn't fix the problem, but with the new APX file, there should be extra logs added to the ARCHICAD logs that might give us a clue about what the problem is.
Find the Fastlogger folder, compress it and send it to me, so that we can see if there's anything useful in them (also tell me when you did the test, so we would know what date to look for). Note that this APX should only work with ARCHICAD 22 build 4023!
| Archicad 4.55 - 27
2019-02-01 02:08 PM
2019-02-06 09:24 AM
dkovacs wrote:It does work.
Let me know if it helped!
| Archicad 4.55 - 27
2021-10-12 01:46 PM
I'm arriving here two years late, but I'm having the same issue on a Mac computer, and obviously the solution can't involve installing Visual Basic components for Windows. Any idea of how I can make the publish to BIMx function available on a Mac?
Thank you in advance!
