Takis
Performance Issues with BIMx (Build 2024, 5910)
I am currently experiencing significant performance issues with BIMx (build 2024, 5910) on my desktop PC. Below, I have included the technical specifications of the PC where I am encountering the problems, along with the specifications of my laptop, where BIMx runs perfectly without any issues.
DELL PC System (Experiencing performance issues):
  • GPU: NVIDIA RTX A4000 16GB
  • Processor: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
  • RAM: 32.0 GB (31.7 GB usable)
  • System Type: 64-bit operating system, x64-based processor
  • OS Edition: Windows 11 Pro
  • OS Version: 23H2
ASUS Laptop (BIMx works perfectly):
  • GPU: NVIDIA GeForce GTX 1070
  • Processor: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
  • RAM: 16.0 GB
  • OS Edition: Windows 10 Home
  • OS Version: 22H2
To resolve the issue, I have already taken several steps:
  1. I thoroughly checked my hardware and replaced the NVIDIA A4000 with a brand new one.
  2. As an additional troubleshooting measure, I swapped the A4000 for an NVIDIA 4060Ti, but unfortunately, the issue still persists.
  3. I also disabled several non-essential Windows services to free up system resources, yet the performance issue remains unresolved.
One key observation is that on my PC, the GPU usage spikes to 100% in Task Manager when rotating the model, while on my laptop, the GPU usage reaches only around 43%.
Could you please advise on what might be causing this performance disparity and suggest any further steps I might take to resolve the issue?
Thank you very much for your time and assistance.
Kind regards,
Takis Apostolides
16 Replies 16
Takis
Dear Norbert, hello,
I've identified that the issue I'm experiencing is caused by the "Anti-aliasing" setting on my PC. However, I'm not entirely sure why this is happening.
Interestingly, I tested the same configuration on another PC with an NVIDIA GTX 1060 6GB, and it runs smoothly and quickly with Anti-aliasing enabled.
The difference of power between the two pcs is enormous and this is what really makes me think what is really going on?
The performance difference between the two PCs is enormous, which makes me wonder what could be causing this discrepancy. If you have any insights, I'd greatly appreciate your advice.
Kind Regards,
Takis Apostolides
Takis
Hi Norbert,
Is there anything else I need to do to forward the issue to the developer's team?
Have you had a chance to figure out what might be causing the problem with the "anti-aliasing" settings in BIMx?
Norbert said to ... "Please send us a feedback with these details from the application. This will automatically create a ticket on our official support channel and we will start the investigation."
Have you done this?
MASz
I have previously raised this issue with the developers. Anti-aliasing does simply perform poorly, even with a 3090.
AC28 AUS, Windows 11, i9 14900K, RTX5090, 128GB DDR5, 4k144 display
Takis
You mean through "Help" >>> "Contact us" inside BIMx?
Can't find anything else with "Feedback"
Norbert Kucsma
Graphisoft Alumni
Graphisoft Alumni
Sorry for the confusion. Yes, use the "contact us" option please.
Kind regards,
Norbert Kucsma
Technical Support Engineer
Takis
Hi, I've sent the feedback.
Kind Regards,
Takis Apostolides
