Since the save as option for BIMx was removed
How do I export my model without publishing it to the web, if I just want to save a BIMx desktop viewer file.
There should be away to save BIMx files anytime then upload them using an upload function under BIMx website.
The save as is the only way I can see to do this.
Can anyone explain why this feature was taken out of the save as menu?
Can we add an option under publish to save to drive, that doesn't look for graphisoft ID or any internet services?
Additionally there is no option to render GI once saved in BIMx the only way is to publish it and choose the option when publishing it.
22 Replies 22
vfrontiers
Also, while I'm here...
I can't save two different BimX's in the same PUBLISHER SET????
They will be named the same thing and overwrite each other...
Am I seeing this correctly?
I've spent some time creating TWO (or more) versions of my files... One as a PRESENTATION piece and the other as a GHOST w/ FRAMING showing thru...
Yes, I can use TWO different publisher sets... but just seemed odd...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Wokka
Barry wrote:
In the BIMx app there is a "Feedback e-mail" link.
Give that a go.
Unfortunatley the feedback email link doesn't work for me.
It really seems to be 1 step forward, 2 steps back with this version. I can't understand 2 major points:
- You can't save the file, so the client needs to learn all about sun, shadows etc
- Being forced to choose GI before generating the file, and the additional time in rendering. I think the renderings are a bit better, but we no longer have control over the quality. We usually open the bimx, check for errors, the hit the GI button. Now we have to publish the file first, check it, and even if it's OK, we still need to re-publish.
Am I missing something???
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
I get a pre-formatted e-mail ready to be filled in.
Or are you saying the e-mail doesn't get through?
Sorry for the late reply but I thought I'd chime in with another PLEASE. Removing the ability to save/set prefs for a BIMx file is just staggeringly misguided.
PS This may be old news but I did talk to AC-support about this. BIMx has been spun off on it's own development path. So ARCHICAD support plead that it was out of their control.
PPS And I also did use the BIMx email feedback feature and did hear back from a BIMx person. I explained our "save with adjusted sun/shadow/stationpoint settings for our clients" workflow. They seemed to understand - but confidence was low on my part because at first they seemed surprised this was a problem for us! Fingers crossed for a fix.
Any many apologies for the multiple instances of this post! >embarassed and ashamed<
Eduardo Rolon
Don't worry. I removed the duplicate posts.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Katalin Borszeki
Hi All,
We are currently not planning to re-establish the saving option from inside BIMx. We are developing towards differentiating the Authoring application and the Viewer’s funtionalities. I hope this responds to your current questions about the disappearance of some of the options. Best,
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Wokka
KatalinBorszeki wrote:
Hi All,
That's fine but quiet often it's just the author that needs to see the bimx. I just found I can't publish without an internet connection, ie it refused to save the local file, and as I am often in remote locations, the internet is dodgy. It just seems way to complicated to create a simple rendered , 3d model that we could do 5 years ago... We are just single operators trying to show our clients their house, that's all. Simple, please
Lumion 12.5/2023
D5 Render
We just recently made the jump from 19 to 21, and frankly the changes to the Bimx program is an absolute disaster. We have all of our clients and consultants using the viewer to help them understand the project and coordinate their work with ours. Being able to save all the preferred setting and having everything ready to go right when others open our model has been invaluable in terms of communication and productivity. Many of our clients do not find the interface intuitive, and having to change multiple settings every time they open a model is frustrating for them, and it wastes our time as we are now answering calls regularly just to help people use the software. Unless this is fixed, or a reasonable work around is found soon, we'll be abandoning 21 and going back to 19 until Bimx is useful again. I understand Graphisoft wants to distinguish the viewer and the authoring programs, that is fine and would work for us. Instead they have taken away a basic and fundamental functionality with no alternate method of achieving the same results. This would be like if there had been no stair tool at all in 20 - because they were working on a new tool for 21. A bad business decision, and disrespectful to all archicad users, to eliminate a such a basic function.
Hans Roest
Hear hear!! Exactly our point (ever since AC20)
It's fine that you want to discontinue rendering and saving in de BIMx viewer app, but PLEASE give us a way to save default settings for the BIMx models (eg. Sun Shadows on)!
