Under the ADD button select the drop down arrow and then library part Parameters.
under your library - probably Object library 22 -- openings. Select the door style and it will list the available parameters. The lower right pane will show the parameters already selected so it might be a good idea to note the variable names before you delete them as many parameters names are similar.
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 26
